2012+ twinairABS is listed as free on the page for this car.
Says no
What am I doing wrong
Red is not free, and so green/orange is free? I'm not sure. Looks like I may have misread it.
Alfaobd doesn't appear to support ABS over KKL cable, looks like needs to be ELM?Only ones in black is free
Cable should work with alfaobd free to read the ABS code
I have used a similar cable to clear an airbag code on a panda
Unfortunately it's not a program I have used on a laptop
First we need to make sure the drives for the cable are installed correctly
Go into device manager and look at
Ports com and lpt
Some instructions here link below
Webasto Thermo Test Setup - DISCO4.COM Knowledge Base
www.disco4.com
Possible let me checkAlfaobd doesn't appear to support ABS over KKL cable, looks like needs to be ELM?
Correct the later post 2012 use Bosch 9 (CAN)Alfaobd doesn't appear to support ABS over KKL cable, looks like needs to be ELM?
the 4x4 uses a different part number, what the differences are I don't knowDo you know if the rear ABS sensors of a standard 0.9 twinair Panda would fit my 4x4? I can't find one that says suitable for the 4x4.
So it was running fine for a couple of months after and failed mid drive,Yes original was EFB.
The only thing I’ve had is replaced the rear disks a few months ago,I’ve seen a couple of mentions of sensors causing potential issues but I can’t see anything I may have touched. Really not sure what else to test.
The earths look okay, I’m not sure what it would look like if it wasn’t though.Let's have a recap of all the symptoms and what's been tried
Start stop has never worked so is likely to be a separate issue,
The ABS, ELD, Hill Hold error started mid journey
Has it ever gone off, since it failed or is it a hard fault
Was the earth under the battery tray ever checked ?
What we know
The shift lights work, clutch switch is probably okay
new battery, same
New brake switch, same
Worth doing a visual inspection but doubt there's any connection to the work carried out
Also worth unplugging each connector, and plugging it back in, checking the wires haven't been damaged by twig or similar
A key difference will be that non 4x4 Pandas have rear drum brakes, but the 4x4 uses rear disks. So very likely the ABS sensor has different mounting?the 4x4 uses a different part number, what the differences are I don't knowDo you know if the rear ABS sensors of a standard 0.9 twinair Panda would fit my 4x4? I can't find one that says suitable for the 4x4.
That makes sense I guess, they all look quite similar online.A key difference will be that non 4x4 Pandas have rear drum brakes, but the 4x4 uses rear disks. So very likely the ABS sensor has different mounting?
Yes does looks like something brake or power relatedThe earths look okay, I’m not sure what it would look like if it wasn’t though.
The sensors also look okay and connected, again not sure what would have changed. Which bit/where would be worth cleaning to see if anything is failing due to that?
I can’t see why they would randomly fail, but the errors suggest SOMETHING ABS related, but no clue what.
Great - shows the benefit of reading the fault codes@Herts Hillhopper @koalar Local garage did a scan, it's a rear ABS sensor failure. None auto parts online appears to have a suitable part in stock (I'm guessing no longer made?). Hopefully it is this and not the magnetic disk thing in the hub.
I can only find a few parts on ebay, some say suitable for 4x4 some say not (but both look identical).
Reckon this will be suitable?![]()
ABS Sensor Wheel Speed For Fiat Panda 319 0.9 Natural Power Rear 51890528 | eBay
Sensor Type: Hall Sensor. Q3: How does the ABS Sensor contribute to braking performance?. A: An ABS Sensor, or Anti-lock Braking System Sensor, monitors wheel speed. Q4: Can I install the ABS Sensor myself, or should I seek professional help?.www.ebay.co.uk
If it fits the diesel 4x4, surely it must fit the petrol 4x4.
Yep rear left.Great - shows the benefit of reading the fault codesBut, did they tell you which side?
The magnetic ring 'can't' fail -- it's either there, or missing. But the sensor can stop working, and is very easy to damage (including when fitting a new one)
As to whether that's the correct part or not, I can't tell you. But, another interesting thing in top menu of this forum is access to ePER -- the Fiat parts catalogue, where you can look up the part number and find out. If I'm reading it correctly (and I hesitate because altough the description says Twin Air 4x4, which has to mean disk brakes, the diagram shows drums) the part number is 51900397 (from here https://eper.fiatforum.com/en/Drawings/Detail/F/F/GIN/33/331/2/70/0/SubSubGroup?MVS=31917D001470), which is different to the part number you had on your link.
Yeah I'm inclined to agree, I did save money replacing rear brakes myself (maybe the course of this ironically, although 4 weeks and probably ~100 miles later), so I think I will. Tough luck on a fun little car (sounding rather entertaining with the custom stainless exhaust), and hard to not be put off it!Its not the sort of thing I'd wan't to be doing myself: its a key, safety critical part and needs to be done right (I'm competent with the spanners, and have tackled the 'difficult' jobs on the 4x4 Panda such diesel glow plugs, but I'd not do that one). £60 to them, plus £35ish for the part = sorted![]()
