General  Duralogic clutch slipping
Northampton
Hi all
I have a 2012 plate fiorino automatic with 78000 miles, I think the clutch is slipping, went to work and noticed rev where high but van was struggling to gain momentum then auto gear box would not change up due to speed of van not being enough, but revs where 3000rpm, the van would cut power then the cycle would start again, if I change gear manually the van still revs higher than it should for the speed of the van.
I am struggling to get quote for clutch replacement due to it being a duralogic gearbox, I have read if new clutch is installed it has to be calibrated to tell ecu that a new clutch is fitted, is this correct.
any recommendation for garage, Northampton area.
regards
Robert
Hi all
regards
Robert
Hi.
Yes its basically a manual.. but with a robot working the clutch pedal
Greys of Warwick have a good reputation.. but an Alfa specialist might be cheaper
The software to recalibrate is €50 so you dont NEED a maindealer
Charlie
Hi.
Charlie
Hi all
Have managed to get a garage who can fit new clutch and recalibrate clutch, cost is £430.00 so not to bad, having to get van recovered to huntingdon, could not find anybody in Northampton willing to do clutch, main dealer wanted £1380 and did not know clutch had to be recalibrated wont be using them, will let every body know how things go.
