fedupcamper
Got it.Re: not getting a fault code after disconnecting a sensor, on my van the fault only comes up after engine has been running for a few seconds.
Thanks, I thought so too. I'll check the sensor values and repeat.Normally the sensor disconnection triggers the error as soon as you turn the key to the ON possition, many mechanics without scanners to clean errors have learned it the hard way, but it really depends on how the ECU was programmed by the guys at BOSCH facilities, so if you want to make sure you are disconnecting the correct sensors you can do this by reading the errors while the sensor is disconnected or by reading that sensor value with the scanner, coolant temp should have a different value when connected/disconnected, MAF is in change of air quantity and air temperature, you can check those as well.
The low voltage value also called my atention, but I guess it is wrong data from the scanner, you can double check this with a multimeter while crancking, it should not be very low as the ECU might be turned off due to low voltage, hence nobody will be injecting fuel to the engine.
As with regards to the pedal value, it internally has different potentiometers which usually have crossed values and are constantly compared by the ECU for any inconsistence, please press it down and check if the 80% value goes down to 20% while fully pressed and the one that is listed as 20% now does get increased up to 80%.
If nothing of this provides any useful information it would be time to check if fuel is reaching the cylinders or try to manually inject fuel via the air ducts, but I'm not yet familiar with these engines as I normally work with petrol ones where we use "starting fluid" to diagnose a fuel injection issue but it is not good for diesel engines.
You would also have to check compression, injectors fuel return, check the timing belt marks, and fuel quality maybe?.
Yeah noticed that too, did I mention I'm on my fourth battery so far? (and it's giving up on me too)
Somehow, this particular car is eating batteries. like I mentioned, fourth battery since 2020-11. I did crank a couple of times, otherwise it's been standing still. Perhaps the living battery is shot and drains the car battery?It's very very low , unless that was after a lot of cranking (without the associated charge whilst subsequently running)
It's a 2020 Ducato, Specs as below: (guide meI see you listed it as a 2.3 in start of post.
Does your diagnostic tool actually work on late vans with SGW, beyond basic OBD stuff, I see you metioned 2.0 HDi at one point which I think is the old Peugeot engine not the Sofim 2.3 used in your size Fiat?
"SGW stands for Security GateWay. Popularly called a Firewall. A Firewall is intended to keep intruders outside. As a result, only officially certified diagnostic equipment is admitted to the internal communication network (CAN network)."
Did you get any higher common rail fuel pressure rreadings as 400kpa is just from the lectric pum,p in tank I think, you should get a much jhigher reading when cranking the engine.
I bought the only one available which was a cheap one.I see you listed it as a 2.3 in start of post.
I don't think so, I checked all the drains, nothing is blocked or clogged. Checked main fuse box, it's dry inside. all the connectors seem to be ok.Do you think that the employee that washed your van could have triggered this issue?:
vid
The "While cranking:I bought the only one available which was a cheap one.
Firmware 2.1 according to spec and what I could read out from the app.
Is that 100% for UK registered vehicles, as I understood after around 2018 onwards it was very likely?That model does not have SWG, when SWG is in place you can not diagnose the car.
