fedupcamper
Got it.Re: not getting a fault code after disconnecting a sensor, on my van the fault only comes up after engine has been running for a few seconds.
Thanks, I thought so too. I'll check the sensor values and repeat.Normally the sensor disconnection triggers the error as soon as you turn the key to the ON possition, many mechanics without scanners to clean errors have learned it the hard way, but it really depends on how the ECU was programmed by the guys at BOSCH facilities, so if you want to make sure you are disconnecting the correct sensors you can do this by reading the errors while the sensor is disconnected or by reading that sensor value with the scanner, coolant temp should have a different value when connected/disconnected, MAF is in change of air quantity and air temperature, you can check those as well.
The low voltage value also called my atention, but I guess it is wrong data from the scanner, you can double check this with a multimeter while crancking, it should not be very low as the ECU might be turned off due to low voltage, hence nobody will be injecting fuel to the engine.
As with regards to the pedal value, it internally has different potentiometers which usually have crossed values and are constantly compared by the ECU for any inconsistence, please press it down and check if the 80% value goes down to 20% while fully pressed and the one that is listed as 20% now does get increased up to 80%.
If nothing of this provides any useful information it would be time to check if fuel is reaching the cylinders or try to manually inject fuel via the air ducts, but I'm not yet familiar with these engines as I normally work with petrol ones where we use "starting fluid" to diagnose a fuel injection issue but it is not good for diesel engines.
You would also have to check compression, injectors fuel return, check the timing belt marks, and fuel quality maybe?.
Yeah noticed that too, did I mention I'm on my fourth battery so far? (and it's giving up on me too)
Somehow, this particular car is eating batteries. like I mentioned, fourth battery since 2020-11. I did crank a couple of times, otherwise it's been standing still. Perhaps the living battery is shot and drains the car battery?It's very very low , unless that was after a lot of cranking (without the associated charge whilst subsequently running)
It's a 2020 Ducato, Specs as below: (guide meI see you listed it as a 2.3 in start of post.
Does your diagnostic tool actually work on late vans with SGW, beyond basic OBD stuff, I see you metioned 2.0 HDi at one point which I think is the old Peugeot engine not the Sofim 2.3 used in your size Fiat?
"SGW stands for Security GateWay. Popularly called a Firewall. A Firewall is intended to keep intruders outside. As a result, only officially certified diagnostic equipment is admitted to the internal communication network (CAN network)."
Did you get any higher common rail fuel pressure rreadings as 400kpa is just from the lectric pum,p in tank I think, you should get a much jhigher reading when cranking the engine.
I bought the only one available which was a cheap one.I see you listed it as a 2.3 in start of post.
I don't think so, I checked all the drains, nothing is blocked or clogged. Checked main fuse box, it's dry inside. all the connectors seem to be ok.Do you think that the employee that washed your van could have triggered this issue?:
vid
The "While cranking:I bought the only one available which was a cheap one.
Firmware 2.1 according to spec and what I could read out from the app.
Is that 100% for UK registered vehicles, as I understood after around 2018 onwards it was very likely?That model does not have SWG, when SWG is in place you can not diagnose the car.
The use of pressure washer was with the engine running.Hello @fedupcamper
Frustrating time for you indeed.
A couple of questions if I may…
The use of the pressure washer by the forecourt attendant - was that with engine running or stationary?
Have you checked that the belt timing is correct as previously suggested by @diego74 ?
Sorry to hear you are no further forward..New update:
After some effort, I managed to drain the entire tank and most of the system from the diesel, thinking it might have been the diesel after all.
I got some diesel from a different station (Avin, one of the biggest in Greece), and also poured in some additives that are supposed to clean the diesel from water, algae, etc., as well. Reasoning behind it was that it might clear whatever is left in the system.
To make a long story short, it did not change anything. Engine still turns over, but does not ignite.
At least now I know how long it takes to drain a fuel tank with a table spoon
(which leads me to a follow up question, is there some type of anti-siphoning protection implemented in the tanks?)
Next, I used starter fluid/spray. The engine shows signs of life, rumbles a bit but does not keep going. I have a few ignitions (although, they do sound muffled).
I had a mechanic come over to try to help, but he couldn't find anything at a quick glance. He checked a few things but was not able to pinpoint any faults.
I double checked that it is not the immobilizer by using the second key. Same story, no ignition.
I've checked all the connectors that are visible to me, all seem fine. I also checked cables and harnesses for wear and tear. All seem to be in order.
Also, wanted to ask the following: When I press the accelerator all the way down, I get to a position almost by the floor where it stops and then "clicks" the rest of the way (in one click). I haven't noticed that before, but then again, I've never floored it in a camper anyway. Is that something that happens in other 2020 Ducato's as well?
Thank you!Sorry to hear you are no further forward..
That throttle click sound odd,
But throttle position does NOT sound like it's related..
It SHOULD start and idle with ZERO throttle input, and it cut out while driving
So back to basics..
You have checked fuel,
Have you added a 2nd earth path to battery ground?
Got reliable readings for fuel rail pressure..?
