Eastendborn
I wonder if anyone could advise me. I have a fiat Doblo jtd 1.9 -2005 model. For two years it has been playing up- and nobody can fix it. As I'm a pensioner I can't afford expensive mechanics. It starts up, and then when I'm just setting off it cuts out. The glow plug light flickers for a bit - and I usually wait for this before setting off. If I get past two cut outs- when I'm on a run- it stays ok -doesn't cut out, it can run on and on -as long as I don't switch engine off. (When I get past the cutting out stage I could drive non stop top Cornwall from London). It cuts out mainly when I've gone a few hundred yards down the road. Recently I have started it on the driveway and it has cut out on tick over. When I went to start it again again - it started then died. A couple of times the only way I could get away - was to rev it like a racing car then drive like crazy down the road - then it would stabilize for a bit. It is worse in cold/damp weather. As I said, it only cuts out when I first start up- and it will do that even after an hour of driving – when I switch the engine off. So I try to keep it running once I have been driving for a bit (after the cutting out stage) even if if I am sitting a train crossing for 10 minutes (so as not to switch the engine off and have to go through the cutting out/non start phase again). I am at my wits -end - fed up with konking out on busy roads when all power goes lights/ steering etc. If you could help I would really appreciate it. W.Jones.
