Styling Debadging an SX
Pink_Cinque
Blackpool
I've looked all over the site for a post about debadging a Cinqu SX.
Which badges have holes in? Or are they all stuck on?
I believe the rears are stuck on, but im uneasy about the front..
serin
***** Friendly
the front ones got a hole and a little sunken bit
and im pretty sure the rears are just stuck one, as the boot lids the same as the sporting, which are always being debadged :rolleyes:
serin
***** Friendly
Pink_Cinque said:
What do you recommend about the front?
You sure its not stuck on?
go open your bonnet and look :p
you should see the back of the badge sticking through the hole
serin
***** Friendly
Pink_Cinque said:
So I should see some little pins stuck through my bonnet?
something like that, im pretty sure theres only one :chin:
it might be cover by insulation, so have a good look (y)
OP
OP
Pink_Cinque
Pink_Cinque
Blackpool
I'll do it tomorrow and report back on my findings, its really damn cold right now :p
I also need to change my fanbelt.
AppleSei
RIP L181 VBB
West Yorks
The rears are stuck on there is a sticky on debadging in one of the sections.
You need to buy a fanbelt and a haynes for the other bit ;)
EDIT someone has deleted the debadging sticky
chaos
Ah. Not good...
All the rear badges are stuck on. Heat them up with a hairdryer a bit first, then use an old credit card or fishing line to remove badges, clean off any adhesive left behind, T-Cut to blend in paintwork.
Front one, IIRC, is held with with 2 pegs and a nut/bolt arrangement. There is also a circular shaped depression behind the badge that would have to be filled (y)
<3Laura<3
Roker, Sunderland
ive tried to debadge the bak of my cinq but theres loads of sticky left behind how will i get it off ive tried all i can think of :(
Carlisle, UK.
As I found out the other day, you don't even need t-cut to blend it in. I used tar remover (allegedly safe for paintwork) to get the sticky off (with lots of elbow grease) and the cloth was red by the time I was finished. That never happened with the Brava!
serin
***** Friendly
Emm said:
any chance i could have the cinquecento sx badges you are/have taken off? pleeeeeeease :D
blimey, never heard of someone REbadging a Cinq :p :eek:
Emm
Fiat Addict
in,on,or lookin at a Fiat
im putting it up for sale at the end of the month, and im most prob gona de-mod it first to get the best possible price
OP
OP
Pink_Cinque
Pink_Cinque
Blackpool
I sent you a PM to discuss the Badges :)
I haven't yet taken my badges off, got more serious problems with my car at the moment (see other posts).
I'm also having a spoiler put on this weekend, which - If I don't get my car driving, I ain't gonna' beable to get it on! Noes!! (n)
