Engine cleaned up a bit.
Drive shafts connected up onto the cinq cups. All new CV boots fitted. Decided to remove the rubber shock absorber on the o/s driveshaft rather than take the joint off. Proved quite stubborn but easier than removing the joint i believe. New hub nuts fitted and staked in.
The camber bolts have been fitted and set to maximum on each side.
Decided that i am going to have the coolant tank where the battery was and make a basic bracket to the strut top as shown:
I still need to trim the GSR hose once the poosition is finalised as slightly too long. I also need to decide which way to run the bottom tank hose as its very tight going down by the mount. Tempted to go over the top of engine as Aaron seems to have done, but ruins the engine bay styling slightly.
FPR Connected up with stainless steel braided hosing. Am going to mount the FPR on the headlight bolt as its in the perfect location (as soon as i can get the 8mm bolt from the stupid black hole below the headlight) Shown below:
You can also see that ive finally taken all the stilo wiring out. Not sure why i left it all in place before fitting, but oh well.
Tidied the battery cabling slightly, but still need to finish off.
In this pic you can see the fun im going to have with a throttlebody to fit as its 4 holes all 8cm apart, so dont think any existing TB's will fit. Have ordered a metal plate 20mm thick to make a spacer from when i decide which TB to use. Think i may just use the bravo one i have sat here.
I have removed the stilo injector wiring and put on the fiat punto sporting connectors. Fits perfectly and makes the wiring at the correct end next to the pressure sensor according to the loom, although will still need extending.
Hoping that wiring wise they should be fine.
Oh and after tightening the sump plug as was leaking. found the hole to be stripped. So see my other thread in stilo section to see what im going to do, which is remove sump, fit oil temp sender while its off, drill out the hole and fit larger plug with a hydraulic washer as they seal better at a lower tension apparently.
Lambda put into manifold ready to connect.
Charcoal canister removed. Hose into cannister was already disconnected and return has been capped off next to the bulkhead.
New servo hose connected up.
Does anybody know what the thing inside the inlet manifold is and what it does; It has a hose going into one end and out of the other????
Dan
