Technical Corrosion to underbody subframe
Nice but the hole is around bald
Removal of the frame is simple
1. Disconnect wishbones from struts
2. Lower complete exhaust
And the transmission tunnel guards and disconnect gearbox mounts
3. Remove 2 bolts that hold the frame to chassis either side of car
4. remove 8 bolts at the rear of the frame
5. Wiggle it out
Tools you will need is a socket set and a breaker bar (impact gun also helps)
You are going to remove subframe, where lower control arms are connected to. I dont think having wheels on and car on ramps is going to cut it.
so i been in a few scrapy yesterday but it was not lucky to found one in good condition ,seen on ebay from alfa romeo but £90 for it ,so i was lookig on fiat ePER
this if front subframe for fiat multipla , subframe have same part number
i think if i am take of the crossrail (i painted in red colour) then i have my subframe i think, i found one near me so tomorrow i am going to have look
fiat multipla 1999-2006
Ok a have subframe now just need cut the piece of metal its weld in few small places
Subframe is painted but do not have place to fit cant do it outside its to cold ,in garage wanted £150 to fit and that is for me lot of money
Still no luck with the weather.worried how im going to get this work done on my car....need to change the sub frame.if anyone has a garage by the way and has experience with this and is willing to help me.i will gladly pay you for the help and the use of your garage.thanks in advance
