General  Cornering lights
Bengie
I hope this isn’t getting repeated but trying to post a new thread keeps failing, this is try number 3!
Anyway, hi.
I’ve recently bought a 2009 panda dynamic with factory fogs and I’ve been led to believe that cornering lights are possible but I can’t find anything in the menu on the dash.
The lights work perfectly from the switch but don’t come on when indicating and/or cornering, is it possible to enable with Multiecuscan etc or have I been told porkies?
Ben
Anyway, hi.
Ben
Why don’t you take it back to where you purchased it from and put the question to them. :)
three Pandas 2005 - 06 and 11
only the 11 has fog lights but no cornering. Might depend on trim level but I haven't seen any on the road
later Puntos yes
Panda I haven't seen. No idea why not most of the lights are controlled by the body computer but it appears Fiat decided not to implement it.
I have the 11 handbook here and double check but odds aren't looking good
Thanks guys, shame as it would have been nice but it’s not like I’ve lost anything.
Hi All
when you say cornering lights, do you mean those lights that come on and go off when you turn, if yes then i think the 2009 car is too old to have them.
Maybe Fiat made a decent enough headlamp that shines wide enough not to have a silly little light coming on and off all the time. also didn't feel they needed then to please a group of people under the pretentions of being safer.
there you go Rant over,
ie make a decent headlight and drive safely in the areas you can see.
Tim
Hi All
Tim
The brightness and beam position of main headlights is heavily regulated
Hence the use of footlights for cornering a lot less restrictions on beams
Hi All
Tim
fog lights aren't real cornering lights although there is a trend to add this functionality to most cars nowadays and looks cool
this video shows what real cornering lights should do
https://www.youtube.com/watch?v=xalQzW9xb94
which goes back to the original DS
but is now only on High end cars
The brightness and beam position of main headlights WAS heavily regulated
IF your panda was new now you could go twice as bright.. without concern about beam pattern ( my rant..)
My punto has cornering lights..
My workmate stopped on the way home one day to tell me my light kept going off :eek:
Worryingly ..
I see it as a signal the vehicle is about to turn left..
Often its a French car with a blown right foglight :eek:
Was it in the advertising blurb when you bought it..?
Some ads are just 'cut and paste'
(A favourite is alloy wheels.. when the panda in the photos has steels)
Charlie
