Copart car
Copart car
Anyone know the best way to clean off the hard white oxidation from alloy wheels? Can i scrub it with sandpaper? Soap and water doesn't work.
It is between alloy and the lacquer.
You can’t clean it off. You need to send the wheel to a specialist as the face needs to be re cut on a specialist machine with a diamond cutting tool.
If you really insist on doing it yourself then most people paint the whole wheel one colour
Ahhh, so not easy, i figured there'd be an easy solution out there, so i'll have to have a think now :)
Don’t use white spirit. You can use thinners which will take off the new paint and leave the oem paint alone. Or you can use a cutting compound to remove over spray.
Sand the old paint smooth. 240 or 320 grit will do. Lay down some etch primer. Wait for it to dry. Sand it back 400-600 grit, then spray on a colour coat. Sand back to 600-1000 grit. Then clear coat.
Halfords sell a selection box or sand paper that has various grades or paper and instructions on how to use them
I've started on the paint job now, i'm setting my bar quite low, it just needs to be the right colour and not have an obviously poorly painted wing when viewed from a distance. The car has been SORN and i haven't done a thing to it apart from start it up every few days. It'll be a much nicer drive than the Puntos i have but as i've not actually driven it yet theres been no rush to get it done. I imagine when its passed its MOT i won't want to drive my older cars and i'll get the 500X fixed promptly. A funtional bluetooth music player will be nice :)
Oh and i checked the paperwork closely and found a service booklet...the car has a full service history, i was like WTF - there's people that buy a car and get it serviced every year?! lol. Its had all of its oil changes, but nothing about anything else like spark plugs or timing belts. All of the service history is from a Fiat dealer, i imagine the car had 2 lady owners who just took it into the Fiat dealer and let them do a service and MOT work at the same time. So thats a result.
The weather is good and i'll have an hour a day for long enough to make progress. I erroneously started sanding some rough areas of the wing with 60 grit paper so its too rough...i bought some etch that will arrive tomorrow...i need to dig out a face mask...i decided not to use 2K laquer because i'd probably need to get a better face mask...
OK, i'm going to sand it all to 320 grit now and then clean it up while i wait for the etch to arrive tomorrow.
I drilled out the bolts that lost their head, see pic. I didn't take much care because i realised i can very easily get a nut and bolt on here, the car chassis does have a built in threaded nut but i don't need it. However one of them was left with its thread. Thankfully the drilling was quite quick, i'm used to using the wrong bits, but at some point in the past one of you guys encouraged me to find good bits and the Parkside ones i have sailed through here.
The etch came and i got the base layer on. The only misshap was that my finger was over the top of the aerosol spray button (see pic) and i ended up with a few tiny drips here and there. I'll have to sand them off tomorrow. I'm not sure if i should put some more etch on the bits i sand off?
It took longer to prep than paint!
I have put etch primer and 2 coats of the paint onto the wing, but it hasn't had any laquer yet. I took it out to see what the colour looks like and its not quite a match. Will the colour only match when laquer is on it? Or did the paint shop not get it quite right? It is very hard to tell.
Silver is almost impossible to match especially if you’re doing it with spray cans.
The colour of the primer will affect the final colour. So while the paint shop may have given you the right colour there is no guarantee of a 100% match
Halfords lacquer aside from being quite expensive, is also not the greatest.
This is possible, but my gut says paying £11.50 is too little for a can of custom made paint, and while the boss is happy to retail at that price the staff aren't. When i got to the shop they left me waiting while i could hear them bitching about various bits and pieces. So not a good enough interaction for me to give them the benefit of doubt.
I've learned some lessons and i'll try somewhere else for the next lot of paint.
I'm going to bung it on anyway, in a slightly despondant mood no doubt lol. I'll have to repaint the wing and two doors. I may be needing a lot of dirt to cover up all the problems lol.
I guess the retail value of this car is sinking by the "repainting", i'll just have to drive the car to its death then lol
I've just been looking for Fiat 348 colour paint and it might have to come from Italy, the postage and packing will be more than £11.50, still looking though.
I'm considering the possibility that I didn't put enough of the paint on the wing / botched it :)
In a lot of videos the paint goes on really wet looking but mine wasn't. I kept the two coats really thin, it was fully covered and not uneven or patchy but maybe it should have been wet looking?
I also definitely haven't put enough lacquer on it, that should also have gone on wet and once again the coat looks and feels too thin.
So now I'm caught between bunging on a wet coat of the lacquer and hoping for the best lol. Or starting it all over again?!
I should really have practised on the old wing, and might do that next.
I wouldn't be too hard on yourself, or the paint shop.
Getting a decent DIY finish with rattle cans is very hard, no matter what yootoobers might tell you.
And as a few of us have said throughout, getting silver to match is notoriously difficult.
I've resprayed a small area on my silver Mazda with a can of official Mazda Silverstone metallic and that doesn't match either.
So spending more on paint probably won't help.
Even a professional body shop would struggle to get it perfect with silver - they'd probably prefer to paint the whole car!
If you can't live with it, then I would keep a look out for another panel, from a car with the same colour code as yours.
And even that might look slightly different!
Thanks for the encouragement!
In my mind i'd decided the mode of error would be drips, scratches or patchiness, not a different shade/hue. So i've struggled with the colour matching problem.
To be fair to the paint shop they made me one aerosol can of paint for my Grande Punto and it was spot on, i botched the body work on that because on a such an old car i didn't care. Its the right colour but you don't want to look too closely lol
They say you learn from your mistakes, so I'm getting plenty out of the way at the moment lol.
The bonnet, bumper and wing will need painting, the other wing and door will need to be blended and the so you’re basically painting the front of the car in an notoriously difficult to match silver,
Just to reiterate the point I made way back on page 1.
Rattle cans are not a good paint if you want a good long term durable finish. you'll find the paint is much softer than the rest of the paint done professionally so it will pick up dirt easier, scratch easier, and will fade at a different rate. So even if you managed the best colour match in the world, given a few months you'd soon know which bit you painted.
Righto, you appear to be saying the task of achieveing of an exact long term match with aerosol cans is very small. I'm inclined to believe that, so i may as well just get on with trying to get the car on the road. Which means getting a thicker lacquer coat onto the wing and letting the colour match be whatever it wants.
I'll practice putting lacquer onto the old wing panel so i don't botch it quite as much lol. I could very easily make a right mess with that...:)
So it really is the wrong paint. The aerosol can has a label which calls it Fiat 348 like I asked for. But it also has a written name underneath which i only just thought to check. The written name on the label is "Grigio Audi/Intellettuale Met"...which is Fiat 348B. The written name of Fiat 348 is "Argento Grey".
Today I tried to get the Halfords lacquer on nicely, but it just wouldn't go on smoothly. So i'll have to junk the lacquer as well as the paint.
Its all part of the fun hey? :) Reminds me of all the mechanical jobs i have to re-do! lol
I'll probably try the company below next, does anyone have any experience of them? Or could anyone recommend a good car paint supplier?
I have used them - really good service. I bought a can of Grigio Trend 645 to paint an Abarth spoiler for my Cinquecento Sporting, went on lovely as did the lacquer. But there definitely was an ever so slight difference between the paint on the car and that of the spoiler.
However, I just put it down to the paint on the car being almost 30 years old, the spoiler isn't metal and it is silver, which from what I understand is a very difficult colour to match.
Give them a go - nothing to lose other than the 30 quid and some time, but it will probably look better than what you have currently got.
Righto, thanks for the link. I'm expecting a slight difference in the shade, depending on uncontrolable factors like fading and primer colour. It wouldn't look like an "inbetweeners" car if I put it on like it is, but it'll be obvious without a second look. I also have two doors to repaint, so the car could end up looking like a patchwork quilt lol.
