Guy's I am desperate for help!!! and sorry for might appear the same old post, I have checked all threads for bleeding coolant, over heating and fan not working and have spent all day trying all the sugggestions.
As I had the dreded cooling fan not working and had replaced everything bar the head gasket I have finaly had the head skimed and replaced the gasket.
The old gasket had definatly passed it's sell by date and I could see where the gasses had passed into the water.
My problem is I have done the following in an effort to fix this but the fan still does not come on
1. Replace thermostat
2. Replace thermostat sensor
3. Replace water pump
4. Replace Rad
5. Replace Rad sensor
6. Replace Coolant Tank Cap
7. Head skim
8. Replace Headgasket
9. Spend 2 hrs trying to bleed system
I fear I may have cooked the new gasket as I turned the engine off because the fan did not kick in I could hear what sounded like water boiling in the block on the gearbox side. I have proably done this twice as my wife said she heard on the second occasion.
I really don't understand what else to do and am off the view that I either have a serious air lock or the new rad sensor is faulty, I certainly hope it's not another headgasket.
Please offer any advice you think might help for example am I bleeding the system correctly, I have been filling the tank until the water comes out of the overflow (only one on this car) and squashing the hoses to try and move the air, top up coolant run engine and try again.
Am I lacking pressure in the system as the pipes do not go ridged and stay soft an plyable.
All help welcome.
4. Replace Rad
7. Head skim
All help welcome.
