Hello all,
Some weeks ago I was trying to close the sei sunroof, I turned the knob perhaps a bit too tight because I heard a click and the sunroof popped up to its open position. In fact the sunroof did not respond anymore to the knob, and I could push the sunroof by hand much further than normal.
I have been trying to close it again, but so far no luck. The knob still works to some degree, if I have a 2nd person press down on the sunroof while I turn the knob then the sunroof will close down (or be pushed up, depending which way the knob is turned). But once the 2nd person releases the pressure on the sunroof, it pops up immediately, as if the knob is too weak to hold it in place as before..
Anyone knows how to fix this? Is the knob just broken, or should I be able to fix this somehow? Btw the screw inside can only be turned a few mm with a flathead screwdriver.
I have read the posts on this issue here, but none of them seem to mention the half working/broken knob (regulator)
