Technical Headlights not working !
Cinq96
newcastle
Hi, Hopefully someone can help.
Early 1996 Cinq sporting, very low mileage, both headlights just stopped working ,both main beams & dips ,sidelights are ok .
When dip/flash lever is pulled ,main beams light up & blue dash light symbol appears.
Have checked all fuses & relays. Handbook mentions fuses for optional devices ,located on side of fusebox ,including a 7.5A for RHD headlight dim dip ,it's ok too.
Any ideas ?!
How is light switch removed if required without damaging anything ?
Ralf S.
Distinguished member
The land that time forgot
Cinq' doesn't have a CANBUS so it's got to be a regular hardware issue.
If the sidelights are working then some of the switch must be okay. I don't know if the halogen bulb is powered on a different circuit but it's "interesting" that the sidelights are still there. If the fuses are good, then I can't think what else the issue could be, so the switch is a good idea to check out.
Ralf S.
OP
OP
C
Cinq96
newcastle
Thanks for your input. How is the light switch removed without causing any damage?
Ralf S.
From memory (last time I looked was about 10 years ago)... I think the switch simply press-clips into a hole in the little shelf doodah so you have to get behind it from underneath (if I remember correctly the back of the switch is exposed) and compress a couple of tabs on the top and bottom and it just comes out (towards you, "into" the car).
Ralf S.
OP
OP
C
Cinq96
newcastle
Ralf S.
Thanks for that info, as it happens the headlights started working again last evening after giving the switch a sharp tap of my finger, so definitely switch related !
