Coolant hose of DEATHHHHHHHH
W
Will
Think my head gasket is gone, what should i look for?
EDIT: Seens as it sounds like it is the coolant hose of death, how do i go about bleeding the coolant system on a HGT 155?
Edit2: Found out how to bleed it, removed the offending item, what a ballache, update is below
Re: Head Gasket failure, what to look for
Symptoms vary but could consist of any of the following:
> Lack of power
> white smoke from exhaust
> high temp reading
> no water left in expansion bottle
> mayo like goo on oil filler cap (creamy/white colour)
> badly coloured water/junk in expansion bottle
> mayo on oil dipstick
Longest Serving BOO Member
1997 2.0ltr Fiat Coupe
- FC Performance Chipped
- Widget installed in dashboard
- EBC YellowStuff with 3G Discs
Only symptom is no water in the expansion bottle, though it does seem to have a lot of mould/residue stuff in there?
Also of note, i filled her up to the brim with water, started her up, ran her at a fast idle for about 30seconds and water was gushing from the bottom, like a hose was on in the engine bay. Deffinately from the back of the engine and towards the l/h side if looking directly at it.
Looks like im gonna have to learn to do a headgasket soon
will
is it not leakin from the water pump, i had this problem on the wife's zr.
I hope not, this is so godamn annoying.
Coolant hose of death it sounds like.
There is a hose that goes from the back of the engine to the bulk head area iirc that is a common issue. It will perish/split and dump your coolant basically.
Common fault on the Coupe 20V and 20VT so its likely to be the same on the 20V Bravo.
If you catch it early enough, you can get away with replacing the hose, otherwise the 'coolant hose of death' is appropriately named.
HGF on a 20V is not a common so I'd basically look into other options first.
From the sounds of it insy that's it, my job on sunday is taking the VIS off and having a good look. Hopefully it is just this.
Again thanks insy :)
Re: Bleeding coolant system on a 155HGT?
will is this that blue bravo u bought off a chap on ere?
i was thinking that mate,i thought that car was spot on!? :s
A Fiat Marea in a Bravo Shell..its good to be different ;)
It's great mike, the fact i drive it flat out everywhere mightn't help.
Anyone any help suggestions on bleeding the coolant?
Okay so ive spent a few hours stripping down bits to get to said coolant hose of death. Had to loosen the VIS unit, remove intake manifold, throttle body, ecu, injectors, coil packs, rocker cover etc etc. Major ballache. Got down to the offending item which is held on with some weird ratchet jubilee clips? Removed the offending pipe, which had a split 1/4-1/2 inch long in it right under the VIS unit. Gonna have to ring around tomorrow morning as most places are closed today. Hose is 30mm ID with 5mm thick walls. Of note is the fact it is touching the actual block in certain place, which looks like it has caused it to weaken. Have orderd some silicone self-amalgamating tape to re-inforce in these areas's too.
Pics below, sorry for the essay, but thought it might help in the future.
The pipe
The hole
Naked 155 VIS engine (blue cover over the cams)
Only problem is the bend at the end, its a 90degree and its pretty tight, doesn't silicone hose fold rather than bend?
glad you sussed it out mate,explains where all the water was goin :) Wouldnt of thought you had to remove the ecu tho to get to it?
but saying that,i didnt inspect mine when i dropped the engine in so who knows how long itll last lol
ring fiat mate,cant be that dear.i got a few things for my car from fiat that wernt that bad on price.lease you know its a direct replacement?
ECU is on top of the throttle body on mine mike, not like a 147 where its seperate in the cabin, and yeh gonna give fiat a call, and a place called aldon who are a tuning specialist
sorry to here that mate but at least you caught it early enough not to blow the engine
ANDY
02 marea weekend 100sx
current mileage: 49500
Bigger is
much better
Another mot done 5 mots and no advisories the old girl is looking good
500 miles and still just over a quarter of a tank left
Check out my Members Page for a list of the full mods
http://www.fiatboo.co.uk/members/367andykent.htm
Will mate, might be worthwile getting a metal one nocked up or try to upgrade it further(heat wrap), mine had exact same problem was a real nightmare to diagnose problem and as you know is a pig to do.
Have you disconnected the VIS system or just reomved manifold rubbers??
F
847
Frank
F
1
6K
Dark Lurker
M
2
379
S
N
2
850
A
V
5
642
Laurie
L
