Technical Coolant change 319 4x4 0.9 TA Any tips.
East
I want to do this job but cant find a new bottom hose anywhere. Im assuming cut the bottom hose clip drain reconnect and refill, but are there any bleed points or dangers to avoid? Im not touching the QR coupling as they never workm after dismantling. Im beginning to think main dealer can do it but there are none withing 150 miles I would trust to look at the car let alone touch it.
If you are thinking main dealer then why not go to the Fiat Workshop in Royston - give yourself a daytrip from Nooorfolk ;) ?
Take the header tank cap of, open heaterknob inside, take lowest coolant hose of, (have a new inox clamp ready).
Reconnect hose with new inox clamp, fill header tank, dont put cap up yet, start engine, let idle for some time, untill thermostat opens, see the level drop in the tank, refill till mark, close cap, let engine cool for some hours, and check level, top up if nessesary, done.
Use pink Paraflu G12 and distilled water, mix in 50% dillution, before filling.
I have donee plenty of FIRE motors (Head Gasket changes..)
Not done a TA, BUT I suspect the Rad bleeds are the same,
unsure if the Heater Hose still has the plastic bleed screw (been a constant since 1990 I'm sure..)
💡 Ask the folks who have done the Waterpump
@TTR.?🤔
@TTR.?🤔
All the hoses are different and all marked 4x4. But unclear if TA and diesel are the same. I doubt it. I believe the rad top hose may be 5 feet long..... Cant even see the bottom one. I cant see the rad top or if there is a bleed screw. I need to get the sump guard off and go under. Im thinking if there are no bleed points found it will be self bleeding. Cut the bottom hose clip off drain via that. Catch the old stuff and measure quantity so I know if it all drained out. Apply top air pressure to clear the matrix, refill with new hose clamp on. Undo header tank and raise it to give more head. No bleed point sugests it should self bleed. My neat antifreeze has top up has raised the protection to 33% so about -20C, but it needs changing it looks wrong, lost all colour and with it having dropped to under 10% protection its done. Not yet 7, though I strongly suspect it was changed by the dealer about 3 or 4 years ago though I need to check the service invoice. Because the antifreeze has never needed any top ups since new and it shoiuldnt deteriorate to this level in 3 years. Incidentlly the heater matrix is ALWAYS full of hot water. There is not flow valve on the heather water as the heater is done by air direction. This car has climate and has no heat control knobs either. My view if coolant should be changed no longer than 5 year intervals.
All the hoses are different and all marked 4x4. But unclear if TA and diesel are the same. I doubt it. I believe the rad top hose may be 5 feet long..... Cant even see the bottom one. I cant see the rad top or if there is a bleed screw. I need to get the sump guard off and go under. Im thinking of no bleed points found cut the bottom hose clip off drain via that. Catch the old stuff and measure quantity. Apply top air pressure to clear the matrix, refill with new hose clamp on. Undo header tank and raise it to give more head. No bleed point sugests it should self bleed. My neat antifreeze has yhe protection at 33% so about -20C, but it needs changing it looks wrong., lost allcolour and with it having dropped to under 10% protection its done. Not yet 7, though I strongly suspect it was changed by the dealer about 4 years ago.
Don't make it more complicated than it is.
It's realy an easy job...
