Hi guys,
because a lot of issues with my car I created separate thread for this topic. Is better to handle all issues/solutions here rather than solve partial issues in many threads.
Overal picture: car Punto 2013 1.4 8V bought with unknown history, 60.000km. Found wry exhaust manifold + burned oil & oil sludge in camshaft area. New oil, spark plugs, flap cleaned, valve clearances checked, compression checked. Car is starting perfect, running well, but main issues were (and still are): high ticking from camshaft area when engine reach operational temperature. By frequency of ticking its camshaft related, not crankshaft (but some piston can meet some valve, thats possible). Another issue is engine noise during acceleration or constant speed. No errors in ECU, MOT passed 2 months ago.
Today guys (who is watching me and my issues) I fond another 2 issues, which are more than strange! 1, I hear ticking also on supercold engine (at morning) directly after start the car. Once engine is heating a little bit, ticking disappear (and its back once engine reach operatiobal temperature). 2, I felt on hand on cold engine that air is blowing from intake (box with air filter), but from connection of piece of flex plastic tube (throug which is air sucked) and big air filter box!!! It means that pressure going from head is bigger than vacuum pressure created by pistons! And that means that some of exhaust valves doesnt seats properly and leak air from cylinder during compression or something like that. As you probably remember, I was surprised that when I unscrewed oil cap, I felt big pressure on my hand. And regarding compression test - when we measured it, we didint have compression tester with proper thread, so we used only extension with rubber end which we pressed down by hand during measurement. And compression reached 12 bar on 2nd and 3rd cylinder, but then it dropped to 5 or 6. We thought that its because of that rubber extension of barometer...but on ctlinders 1 and 4 we successfuly measured 12 bar without drop.
Plus I know that someone before did head repair because I saw that exhaust valve on 3rd valve was shiny like new oposite to other 3 ex valves.
So what now? Leave whole thing as it is? How is possible that starts are always perfect and car is running good?
Very very strange, specialy why I feel air going from airbox out instead of sucking air in? Of course when I remove whole filterbox, flap will suck my hand inside
But also color of spark plugs is ok, all the same like white coffe and as I said, car passed emission control 2 months ago...
