Technical Connecting the dipped beam 'rocker'!
ajm1986
Cheshire
Hi Everyone,
Fiat Punto, Mk 2, 54 REG 1.4 Sporting. :slayer:
Long time user, first time poster.
The other day my car head light units came up as a fail on my MOT and so rather than spend the ridiculous prices the garage wanted to replace them I decided to go at it alone.
All went well and good UNTIL it came to re-connecting the little switch box that electrically moves the dipped beam lights up/down, controlled from the up/down toggle switch on the dashboard to the left of the dial cluster (I hope you get what I mean from my description). :confused:
I cannot for the life of me :bang: get this connected in to position and so I'm wondering if any one has any tips or tricks for getting this in?
Just to clarify - its not securing the switch box in to position I'm having trouble with, it's physically getting the little 'ball ended' rod connected in to the grooved slot that is mounted within the headlight unit.
Any help / tip / tricks / or even guide on how to do so would be very much appreciated! :worship:
I look forward to your responses and thank you in advanced.
Andy.
the motor has a 0 on the end the bit you are connecting into has a u shaped entry so you have to like slide the motor on sideways then clip it in to headlight housing
they are a real pain i would prefer to do it with lamp on knee
Thanks fr the reply s and b, much appreciated.
Its as i thought then, there is no simple way to do - sounds simple on the surface but then actually doing it as you say, is a real pain.
Ill have another crack at it.
Ziggy, cheers for that little bit of advice - I tried heating but I don't think it did anything to help to much!
I did in the end get it in to position - took the light out of the car again and sat at my desk at work until I had done it, took me about 20 minutes in the end, probably alot longer than it should have done.
Thanks again for you input (y)
Hi Everyone,
Andy.
how much the garage wanted for this i wonder
