can any one tell me were i can get a manual in pdf so i can have ago at diong it myself pls,thanx
Ther obviously isn't one, so buy the manual.
Cheers
SPD
I've only seen the Cinq manual in pdf in Polish and Italian. The Haynes should be OK.
With hydraulic tappets there should be no play at each check point. Check the same as you would manual tappets, rule of 5 or 9, your choice.
Cheers
SPD
will do, ive been told it will be the tappits if it does that, so ill have a look
had a look and 1 and 2 followers are not lifting so could it be the cam or followers
Are you saying the pushrods aren't moving at all?
Cheers
SPD
yeah no 1 is a bit bot no 2 is not moving at all
