Technical OBD Port on Seicento S 1999 899cc
Tomobelli
LEIXLIP
Hi Folks,
Can anyone confirm if 1999 Seicento S 899cc has an OBD port.
Online searches are saying yes and that it is located under steering wheel column (RHD) and above the pedals but I can't see one unless I really need a trip to Spec savers 😎😎
Please Advise
Thanks in Advance.
Hello, the 899's are the old 3 pin ports which are in the engine bay by the ECU, you should be able to see it as the wire tags of the loom near the ECU it has a cap on the end which unclips & reveals the 3 pin port, here is a picture of the wire with the cap & location
  • Like
Reactions: ben
Ah brilliant, fair play,
Thanks FiatMatt94
Great photo
My OBD2 16 PIN is no good to me so I guess.
Is there some kind of adapter that can connect the 3 pin to the 16 pin of the obd2 scanner?
