Cinquecento Cinq Abarth Project 1.4 16v
Its been a while since Team Lloyd did any projects, so yesterday we travelled miles to pick up this little gem!
Over the winter we hope to transform this cinq into possibly the first 1.4 16v with 6 speed gearbox, not sure if anyone has done it yet, altho have heard people thinking about it!
We now have the car and a brand new 1.4 16v engine and gearbox awaiting to be joined as one!
The photos:
Emma.
  • Like
Reactions: Donna
Some details on that rear stab. bar please ;) /Woj
The rear anti-roll bar is a modified 19mm anti-roll bar from the front of an MGF shortened and welded together.
Its held in place with front Cento anti-roll mounts and bushes on custom made mounting plates welded to the rear beam.
It is then fixed at bottom with Lancia integrale EVO1 rose joints (any rose joints would do but had these at hand) with custom made mounting brackets fixed to the bottom damper bracket, this will be further modified so the bottom of rose joints is at least in line if not higher than bottom of the damper to give better road clearance.
Once its painted up we'll get some pics of the custom mounted where the battery used to live Grande Punto expansion tank, and how much or how little clearance we have between the top pulley (this is a vari-cam thingy so bigger) and the headlamp unit, its about 15mm all round, but as engine moves backwards under load should be fine. To further protect against this the engine mounts have all been uprated using Tiger Seal which is polyurethane, can't quiet believe how stiff they are compared to normal, can barely move the engine.
Yes, it is spring loaded with a tension mark.
You tension it with needle nose pliers, or the special fiat tool, torque up the nut, do two whole rotations of the crank, and check the tensioner mark still lines up, if not repeat.
That one in the pic is not teneioned 100%, but is pretty close. it can be a big pain to get it bang on
Kristian
Not many updates, but it is getting ever nearer completion.
Still waiting on the Sparco roll-cage to arrive from Italy, Aug shut down doesn't help, but hopefully soon.
The exhaust has been made, with a rather cool exhaust hanger bracket fabricated to be part of the anti-roll bar brackets on the rear beam as we removed the original exhaust hanger from there to accommodate the anti-roll bar.
A full set of Punto HGT brake callipers have been bought awaiting arrival, and I'll soon be ordering some Pinto HGT brake disc's as the fronts are slightly thicker than Punto GT ones 22mm V's 20mm which seems like nothing but makes a big difference to price, but will dissipate heat better. Also have the option of fitting a set of Wilwood front 4 pot callipers as recently purchased some massive Mitsubishi GTO 4pot brake callipers and a 325mm brake disc conversion for Emma's FTO which at present runs the Wilwoods with a 297mm EVO4 brake disc conversion, the Willwods say min disc's size is 250mm which puts them plumb into the HGT disc size territory.
But biggest update really is ECU choice which was up until now going to be Emerald as we used in the Seicento to good effect. But a while back I noticed a new ECU to hit the market which has been getting advertised a lot in mags trying to increase public awareness, so looked into it and liked what we saw, so we are one of the first to try it out and as such got a very good deal, in fact too good to be putting on public forums! Its http://www.canems.co.uk for anyone interested in that stuff.
I will try and get some pics over the weekend for updates.
why that one over Emerald? Was it the built in data-logging that swayed it? Does it only support the 36:1 trigger wheel too ??
Hi Mark,
The data logging facility is pretty good, given as the cars being built for track days. To quote the website "RPM input from either VR or Hall effect sensors with 36-1 or 60-2 toothed wheel"
Few reasons really, its built inside a water proof Bosch type ECU case with Bosch type connection so can be fitted under bonnet like OEM Bosch, it also has ability to use all exsisting sensors as these are all configured for Bosch ECU's. We can also use the Emerald map from the sei and in Chris's words move stuff around to suit for a decent base map before it goes on the rollers for proper set up.
Aaron.
coolio.
i did look on the website, but could only see mention of the 36:1 wheel - guess i should've looked further into it. I like the casing on it, and noticed it has internal relays for fuel pump etc. re the sensors, did you not do that with the emerald? or did that require changing some of them? I know mine runs the sensors the engine came with (wideband lambda asside!)
The Emerald ran all the sensors we had on the Sei, though we did use a K-series throttle body and sensor which the Emerald was originally deisigned for in Kit-cars, Se7ens etc
The internal relays etc are a good feature, though on the Sei we just used teh standard ones which were powered by the Emerald TBH i've not really looked into it all, its moved pretty quickly from seeing an advert in a mag to receiving one :)
What sort of price range do they start from? Are they able to run wasted spark etc?
If they are good I might be interested in one instead of a MS unit.
Look at the website, most of the info is there:
Injection ECU Features
• Fuel injection control for 4, 6 or 8 cylinders
• Wasted spark ignition for 4, 6 or 8 cylinder engines
• Built-in coil control (no need for external ignition modules)
• Two 3D ignition timing maps with 180 programmable sites
• Two 3D fuel injection maps with 180 programmable sites
• Fuel / spark map switching at run time
• 12000 RPM capability
• User programmable hard and soft rev limiters
• All settings real-time programmable
• Semi-sequential injection control (four cylinders)
• 3D injection advance map with 180 sites
• Tested and developed with siamese-port multi point injection
• Support for one, two or three Bar MAP sensors
• MAP or TPS based load sensors
• Programmable speed and load sites
• Programmable transient enrichments
• Staged injector control
• Built-in main relay control
• Adjustable coil dwell control
• Voltage sensing with programmable dwell correction / injector opening time map
• Coolant temperature input with programmable correction map
• Air temperature input with programmable correction map
• Programmable cranking characteristics with temperature correction
• Two lambda sensor inputs for narrow band or wideband control
• Closed loop lambda control - programmable feedback rates / authority / enabling conditions
• Adjustable target air fuel ratio with wideband lambda feedback
• 3D target air fuel ratio map with 180 sites
• Closed loop idle control with programmable feedback rates / authority / enabling conditions
• PWM valve and / or spark scatter idle control
• Programmable fuel compensation map for idle valve
• Cooling fan output with programmable on / off temperatures
• Programmable shift light output
• 3D PWM output with 180 programmable sites (open loop turbo control etc.)
• Interpolation on all maps
• Diagnostic recording of min / max inputs and outputs
• Data logging of up to 24 optional parameters
• Adjustable recording rate for data logger
• RPM input from either VR or Hall effect sensors with 36-1 or 60-2 toothed wheel
• Tuning software, PC connection cable and loom plug/pins included
its not really VVT, just alters the exhaust cam on startup to heat the cat up quickly.
iirc there is a plate made up with two channels in it, depending on which setting gives the most power deciedes which channel the oil will be left flowing through!
