General  Central lock problem
Dzso
Hi all!
I have a problem with the rear right door central lock motor. Can I change the motor aftermarket or I need the original? Punto ELX 75 1995
Does it have 5 cable or only 2 cable?
best thing to do is remove the panel and look. you can also test the wiring with a meter whilst there. There will only be a short pulse but enough to check its ok.
As for aftermarket or original then the choice is up to you. either will work.
