Dzso Member Joined Nov 12, 2021 Messages 28 Points 87 Nov 18, 2021 #1 Hi all! I have a problem with the rear right door central lock motor. Can I change the motor aftermarket or I need the original? Punto ELX 75 1995 Does it have 5 cable or only 2 cable? Last edited: Nov 18, 2021
Noddy Bugs Beware!! Joined Feb 24, 2008 Messages 568 Points 199 Location Wisbech Nov 22, 2021 #2 best thing to do is remove the panel and look. you can also test the wiring with a meter whilst there. There will only be a short pulse but enough to check its ok. As for aftermarket or original then the choice is up to you. either will work.
