Technical  Can't find fog light fuse
Turbo642
Portugal
Hi guys, I have a mk1 punto with a little problem, the front fog lights are not working, it's not a problem with the bulbs because they're good there's simple no power coming to the front, also inside of the car when you press the button even the little light on it doesn't respond. So for starters I tought it was a problem with the fuse or the relay, but I can't find the stupid thing. I checked on autodata and it says that it's supposed to be on the fuse box in the passager side, but it's not there. There's any other place where the fuse could be? It's not either on the main fuse box... only the rear fog light is there.
Model
Punto 1.1
Year
1994
Mileage
00000
Thanks man, that gives a big help. But I already found the bastard, it looks like that the fog lights didn't come with the car, it has been installed, which explains why the relay it's on the engine compartment, I would say that it was been put on the dealer, because of how good it is installed and with original parts like the relay itself.
I've been trying to diagnose the problem anyway, and I came to a part where my technical knowledge is being limited, so I already have power going to the fog light's wires and the button inside of the car lights up, but when i connect the wire on the fog light/lamp the relay shuts off. It looks like some type of short but I can't find it
