Technical Calibrating???? Speedo
ryang
I disconnected my speedo earlier (without disconnecting the earth) and took it apart to clean inside, including taking the needles off. now when ive come to turning the car on, all the dials are incorrect.
I have now taken the speedo out this time disconnecting the earth, and re positioned the speedo and rev counter needles in the correct place (at 0) and i presume this will sort them out, but still both the petrol and temp gauge are rising right to the top, despite the car not being full of petrol and it being cold!
What can i do??
OP
OP
R
ryang
What plugs do you mean mate?
theres only one plug in the back of the speedo
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
you have caused yourself a hole host of problems buy removing the needles in the incorrect sequence in fact needles should never be removed really
I bet you were trying to fit white dials weren't you
if you have mk2 punto
and you disconnected can lines from the dash (which you did) you now need to take it to the dealer to have it proxy aligned
if that does not work you will need a hole replacement dash
OP
OP
R
ryang
thanks for the input mate,
wouldnt a new speedo suffice and not the whole dash??
The Sultan
Bravo 1.8 HLX FTW
it's mk2 you cant get just a new speedo there is an exchange service at fiat were they take your old one for a reduced price on a new unit
you then need it fitted buy fiat to add on the correct number of miles and have it proxy aligned
The Sultan
Bravo 1.8 HLX FTW
o sory buy dash i mean dash pod
but when you say speedo in my mind that refers to just the speedo clock not all of the clocks as a collective for example dash pod
