Did you swap all the key parts including the glass vial transponder?
Yes, just swopped the blade. Everything was as it should be, the buttons on the remote even locked and unlocked the doors. The only problem was the imo.
The transponder should be recognised by it's matched BC which then sends an "Allow Start" signal to the engine management ECU. I don't think the EM ECU holds the key code as well, but just in case it does, you could try swapping the EM ECU too.
I did consider that but what I really wanted to know is if a second hand BC can be used without anything else. Purchasing BC, engine ECU, Key etc. would be very expensive. Paying Fiat £90 to re-code the key is much less hassle and cheaper.
U1600 would come up if you've used a key with the wrong transponder.
The reciever coil "thingy" is only a coil, it just picks up the code from whichever key you have close to it.
Thats exactly what I thought but it would appear not to be so?
You could have tried it by wrapping the "wrong" key handle in thick Bacofoil so you could use it to turn the ignition (the Bacofoil would prevent the transponder signal getting through to the reciever) while holding the "correct" key (and transponder) close to the reciever.
Just swopping the blade of the key should have been enough as I did use the correct key(transponder) or the doors would not have locked and unlocked.
Just a thought (because of the error message)... perhaps FES can only Proxy-Align one node at a time. I seem to remember that when Yani was investigating Proxy-Alignment for FES it was so he could Proxy-Align a retro fit CN+ into his Stilo to avoid the need for the 4 second delay circuit, not to configure multiple NODES.
If feeling adventurous, you could try disconecting all the extra NODES then reconnect and Proxy-Align them one at a time.
Proxi-Alignment worked, it reprogramed 4 NODES successfully. I just told it to continue. It reprogrammed the Multiwagon BC with all the NODES of the project car. It worked 100%.
