Technical Break lines/Hoses incorrect assembly.
rorymn
Hi People, new here for this reason no more googling can be done, there is nothing I can find out about this problem.
The car failed the NCT/MOT on a few things but we got everything done and working as good as new again, just this one thing we can not get our heads around, we got a fail on this..
"Break Lines/Hoses (47) Flexible Break pipe incorrect assy OffsideFront and NearsideFront"
I have no idea, the break lines are working fine and there is no problem?:bang:
Does anyone have any ideas?
I can post pictures if needed!
Thank you in advance for any help given!
your hoses should look like my picture otherwise they rub through and or stretch causing no brakes
you have a proper tester there thank him
I think thats what they do look like, trying to post pictures i just need 5 posts first
good pic that :D
is this punto on fork lift truck..
car looks like its in mid air.
i downloaded it for threads like this but it looks like a wheel free ramp to me:)
ive looked again yes a forklift
those pictures posted up last one looks wrong but quality is proper crap:p
Fantastic Ill get them switched around ASAP
you'll struggle - your missing 2x brackets which allow for this
You need to visit a scrappy and see if you can pull them off
They seize and rot together - so many people simple snap them off
Dont bother redrilling the brackets bolt hole and sticking a fresh nut and bolt in
As a result - you end up with your problem
Trust Me and S+B you are seriously risking your life
I had 1 side like yours, it ruptured 1 hose, rubbed another hose to the cords which would burst at some point
Stopping from 80mph, downhill towards a redlight - IS NOT a fun experience, more like lumpy pants
Ziggy
Ziggy
any photos:cool:
not of the pants mind obviously(y)
any photos:cool:
im affraid not, its not something i took pictures off - i was in a hurry to be back on the road
Its when i brought my first flare spanners too!
Anyway
i knew it'd rubbed a little - and 1 day a heavy braking session and Bang (pedal drops to floor) and you are left with little braking, you still get that 50% one hit stopping power due to the tandem m.cylinder but still....
i didnt know that because i had the missing mount - that was the cause of the rubbing
Eitherway, i fitted a new one, none the wiser - and MOT time, it failed AGAIN because it had been rubbing...
Annoying i replaced it, found the rot was bad and ended up waving Bye Bye to it :(
Ziggy
