Justa reflex thinking out loud with brain in neutral , maybe the lock is further than Fiat intended because of wear or damage and it pulls or pushes the hoses a bit.
they're both wrong then,
probably a lash up when you had both struts done.
And that's my thousandth post![]()
Thanks. That was an interesting read. In reference to this picture that ziggy posted:
The bracket into which the rubber grommet goes on mine is vertical rather than horizontal. Now I'm even more confused. I really can't see where another bracket could go on mine.
hi Firthy the brackets that bolt onto the struts are handed this is probably confusing you
you do realise the reason your hose has gone is because the former keeper bodged this job or his garage did dont you?
see if you can buy the brackets off a scrapper or look on say ebay or if all else fails then a fiat dealer
its not safe to drive it as you have it at the moment
sorry![]()
Ah. So the bracket isn't "missing" from mine, but it's in the wrong orientation? i.e this one:
Apologies for the stupid questions.
Theyre the ones you don't ask![]()
no the bracket bolts on to that bit
