General Bravo Wings To Marea???
Jekoviq
Hi guys. I`m gonna instal Bravo Tuning front bumper on my Marea, so i will need to change the wings from my marea to bravo ones. My question is - Is this possible? I mean - they will fit i`m sure - but i`m wondering if the distance between the wing and the tire(on sides) become different from the stock - marea wings.. Or is there any problem to place bravo wing on marea body? I really need someone with expiriance..
Оn the pictures - this is the front bumper i want to put on my Marea!
And i`m really sorry for my bad English but in my country it isn`t official ;)
Having owned a Brava and a Marea I think you will not have too many problems but you will be lucky if you find someone who has done this before. I do not think you will have any problems with clearance on the wheels unless you go completely mad with your wheel choice.
Good luck:)
Thanks man - i don`t know i will try just to see the result!
i wouldn't bother, i would modify the bumper to fit the wings, that has to be less work?
Yes man at the begining i was thinking that i will just cut the bumper from both sides while the bumper is placed - but if i do so the wings under the wings(the plastics covers i don`t know how you named them) they no longer be able to be attached to the bumper :(
As said, it depends on the model marea/bravo/a you are swapping from.
To the best of my knowledge, all 3 cars (Marea, Bravo/a) are identical (bar a few cosmetic changes) until the b pillar. The front wings will fit from model to model. The only difference being cars with the 20v engine in as the wings are wider to suit the wider wheel base at the front. The wings from the 20v will fit the standard models but you will need to change the bumpers too and side skirts if you have them fitted.
Hope that helps.
