Bit sketchyYes, I do.
you can lift the front, chock the rears and spin the wheels up,
I have tested a rebuilt gearbox this way, before flushing and filling with expensive gear oil
You will get an ABS error, as far as I remember that error self clears once you drive the car normally
It's surprising how slow the wheels spin even at 70mph
You will have to use the brakes a few times to be a fair test
My car has thicker alloy wheels I have just done 10 miles down a dual carriageway and pulled up fairly gently 3x popped my hub caps off, the center is still cold and the disc are too hot to touch
