Hi There
My handbrake will not hold the car on an incline even though its pulled up to the last. I took off the drums and the shoes look ok with enough friction material on all shoes. The cylinders are not leaking and are working okay. The handbrake lever mechanism on the backplate is loose and not seized.
How can I know if the adjusters associated with the brake shoes are working?
I looked underneath the car at the handbrake lever where it enters the "transmission" tunnel and I can see there is a threaded rod where some adjustment can be done. How can the handbrake be adjusted?
rgds
rgds
