shortie
BTW, Bebbe and Paulbfd... Very nice wheels
I upgraded to 15" wheels and tyres on my 1.2 dynamic and there is a massive improvement in over all road holding and ride quality![]()
On 16s and best looking Panda on forum IMO :yum:
I would be tempted to put 16's on my panda. The 15" fiat alloys i've got on there could do with being an inch wider. As trackdayqueen has mentioned before on another thread the standard Panda has a major problems with understeer. Maybe I just need a wider track tyre...And a new suspension set up and a couple of anti-roll bars.
hi bebbe, yes the car is lowered. i had the suspension fitted and didnt actually say how much i wanted it lowered but ive got a feeling they dropped it all the way so i think the kit lowers to 40mm or something like that.
glad you like the look though!![]()
Personally i think a mini cooper with 15s looks fine to me. It will handle better with smaller rims too.
My integra type-r has 15" rims. To put bigger wheels on would be asbolute blasphemy.
Hi Bebbe i have had 7x16s et 37, on my old mj sporting, 195x45x16, on full lock they scuffed the inner arch near the bulkhead, this was only very small though, loads of rear wheel arch clearance i even pulled rear spring to check when bottoming out, but it needed lowering due to my job i never bothered, i then bought some 7x15s et 38, 195x45x15 no probs at all, both sets of alloys/tyres improved the standard handling no end, no longer would the front understeer and wash out leaving you with more lock applied than needed and would go in the direction chosen, i then sold mj and got the 100hp, and bought new wheels/tyres again 6.5x16s et38 195x45x16 i have no issues they do not scuff or rub and compared to the original 100hp wheels and tyres these seem a lot lighter, the handling is as it was also, Bang On.
People just don't get it. Great cars like the 205 GTi, 306 GTi-6, Renault Clio Williams, Clio 172, 182, 197, Integra Type R all handle great because the manufacturers worked so hard at the suspension setup for the standard rim size. Go bigger and your car might look slightly better but it will handle far worse.
Felix27 i totally agree, and 306maxi small increase yes for looks but do you really think swapping the tyres dont make that much of a difference to understeer,Wider tyres aren't going to make your car understeer less![]()
going from the standard panda 165/65/14 to a 195/45/15/16 is a wider tyre it also has a lower profile yes, it has a bigger footprint so should ? grip better or is that wrong ?, and the tyre rolls less is that correct ? the profile and stiffness of sidewall giving better and more surefooted cornering, so should reduce understeer ? i understand many Hot Hatches were designed to run standard wheels profiles etc, i have also noticed that many people still replace these on sporting days and run at the front not the back, but i may be wrong againi think Bebbe only wants to know from the looks department what will fit, do not think his or my Panda will be at Spa or Silverstone next year do you, mind you after reading this Fiat might ask Lotus to sort out the entire Panda range then you may have an argument that holds up. Bebbe have a look http://www.1010tires.com/WheelOffsetCalculator.asp English is great Bebbe dont be sorry.
going from the standard panda 165/65/14 to a 195/45/15/16 is a wider tyre it also has a lower profile, it has a bigger footprint so should ? grip better, and the tyre rolls less the profile and stiffness of sidewall giving better and more surefooted cornering, so should reduce understeer ? i understand many Hot Hatches were designed to run standard wheels profiles etc, i have also noticed that many people still replace these on sporting days and run at the front not the back, i think Bebbe only wants to know from the looks department what will fit, do not think his or my Panda will be at Spa or Silverstone next year do you, mind you after reading this Fiat might ask Lotus to sort out the entire Panda range then we may have an argument that holds up. Bebbe have a look http://www.1010tires.com/WheelOffsetCalculator.asp English is great Bebbe dont be sorry.
Perhaps a little. But remember you will now have more grip at the back to overcome the increased amount of grip at the front so any lessening of understeer will be minimal and balanced out by my next point.This is kind of true. The car is still set up the same so will have the same understeer tendencies but with a bigger amount of grip at the tyre/road interface it will take more force to overcome it before it understeers.
Chris
Hihi.... no one can say that a standard Panda with standard 13" wheels will handle better than the same car with 15-16" wheels. With the standard 13" the car will skid and understeer even in leagal speed.
And yes, you can at some amount balance the understeer with rims and tyres. Just take a look att the Opel Speedster (Vauxhal VX220). Just change rims on the car and the handling improves extemely much.
And ofcourse I will not have my Panda as a trackday car (have an Opel Speedster). It will be a comuter car. But just to stopp the car beeing everywhere on the road I will mount some bigger rims and tyres. And it make the car look better to.
