looking in the engine bay, you will see a thick pipe connected to the right of the radiator that also connects to the engine at the right hand side. behind that pipe on the engine side is the thermostat. you can do a quick check to see if it works without removing anything. start the engine, while it is heating up you should notice this fat pipe is cold. it should remain cold until the thermostat opens. then it should get hot fairly quickly. if the pipe remains cold once the engine is hot it means the thermostat is stuck shut, if the pipe gets hot very gradually and the engine takes a long time to get up to the half way mark on the gauge, it suggets the thermostat is stuck open. unless you are having problems with the engine overheating or taking too long to heat up, i would not touch the thermostat. it is a basic mechanical valve and can not cause any other problems.
