Technical  Battery terminals
shazzyboo
Herefordshire
I am new here and have no idea if I'm using this site correctly. Need new battery terminals for my Fiat Panda Eleganza 2004. Does anybody know where I could buy some from, please? The previous owner must have done a bodge job as they are just sitting on the there.
Yep that's what happens when they are grossly over tightend .
Try ebay
Look at fiat 500 ones too could be the same part if you look carefully.
Petrol and diesel types could be different.
old faction beakers would be good
the would be tossed into the scrap metal anyhow. My local breakers would charge £5 there mini order
Pretty much every Fiat is the same. Early Pandas didn't have the cam lock, which is nice to have
In the meantime.. if you are struggling
Ive found over the years that:
The posts are tapered..and in 2 sizes
Option 1
Slacken bolt .. use a screwdriver to open the clamp.. 3 or 4 mm gap
Use a Socket to tap the clamp down the taper.. then gently tighten the clamp.. when you think its tight.. try and twist the clamp
If it doesnt twist..its tight enough :)
Too small - or big..
A small piece of 15mm household copper pipe cut to @15mm tal..and slit down its lenght makes a very good..and conductive.. spacer
