The Panda Nut
Nutty about Pandas Infected by Panda virus and OPD
SO far this week I have had to buy two batteries. I replaced the one in our 2011 car with the bigger one from the 2014 car. That promptly died after about a week. After a battle with websites to get my GEM discount from halfords their top battery installed for another £75. I decided to run a welter of tests on the system just in case its not just a case of two batteries failing a week apart. Result is that there seems to be a discharge going on accoerding to my Gunsons test tune. SOmewhere around 0.1A to 0.5A. This is a fail and falls into excessive discharge apparently. I checked the oterh car andfound initially it seemed the same but after a few more minutes its drain fell right back into the green c. 0.01A.
Investigating, I can only find 1 fault and that the boot lock has failed. Muck has again caused the handle / micro switch to stick. A load of very fine dirt in and around hte two pivots meant when you pulled the handle it did not return. I don't know but suppose this means ongoing power to the solenoid rather than just a shot when the handle is pulled. My son is a physicist and say its unlikely to cause any significant drain at the solenoid is not constantly operating. Anyway its free and working again ready to refiit in the morning. It took a hell of a lot of fiddling to get it working again but the switch now clicks on and off again so should be fine. While all the lock and handles were off I retested and the drain is still there so its not the boot causing any issue.
I ran MES and the charging seems 100% 14.2V with full load on. The only fault code showing was to do with electronic key not recognised. I think this was a week or two back and resulted in the immobiliser light being on when the old battery went down. Fault is not present now.
I am hoping someone else may have a suggestion of something they have identified as a drain to aid me in not having to grovel on the floor pulling out each fuse in turn. The cars running well and is not showing any symptoms other than failing the residual drain test. I dont want to knacker another battery as this one is new.
I have located an old charger to try and charge the old battery as the smart charger wont even recognise it as a 12V battery in spite of it showing 12,6V. If itd actually dead it may be that it is just a battery issue. If it rechagred though the car will be the culprit.
Ideas or comments would be appreciated.
