Hello all, my punto is having issues starting. Turn the key and the starter doesnt want to budge and the clock goes to 00:00. Been doing this for a while and the car is worse if it's not been used for a couple of days.
Other times I've been able to start it with a small amount of accelerator applied.
My thoughts are that the battery has gone because once you've got the car started it'd be fine for the rest of the day but i'm concerned it could be a power drain.
What are everyone's thoughts?
When you turn the key - yolu get a click and the car doesn't attempt to start
and the dash resets
That actually sounds like a fault when i fried the earth return cable
rolleyes
Anyway some basic tests
AWhat is your battery voltage when its sat?
BWhats the battery voltage when the engine is running?
CWhat is the battery voltage with the electrical stuff on (heaters fans lights stereo etc) at idle?
DSame as above, but this time with about 2k to 3k rpm?
A Should be between 12.2 (low) to 12.6v (charged)
B should be 13.8v + If battery is dead its more likely to be 13.8, but 14v+ if its healthy
C Should remain about 13v, but i know the 60a alternator dont have enough juice, i've seen as low as 11.5v (serious sucking)
D Should be happily sitting 13v + (i'd expect 13.5v really)
Next for starting, get a negative jump lead, attach it to the engine mount posts, and then the other end to the
NEGATIVE BATTERY TERMINAL
i say it in big letters because, you put that sucka on the positive, You'll create a heavy short
Anyway with the mount to negative terminal, does the car start with ease?
Ziggy
