Re: Rear suspension bush leaking something
Your rear suspension bushes are fluid bearings- a bit like those ghastly cough sweets with syrup inside them - a tough outer case with thick oil inside- so they allow some steering or tracking movement of the rear wheels when cornering to make the back end tuck in better
Looks like the outer seal has gone on one of those bushes and it's that fluid now leaking out
Replacement rear bushes I'm afraid. Have a look in the Stilo Guides to see how some people have managed them but my advice would be
GET SOMEONE ELSE TO DO IT
If you are going to do it yourself then I would do as some others have done after removing the rear beam, swipe out the centre rubber bush part then hacksaw through the outer bush sleeve just enough without damaging the hub so it allows the sleeve to collapse inwards , then it should drift out fairly well
Pressing the new bushes back in
I'd really clean up the hub inside and use plenty of lub but, to get the power to force the bush in, you're going to need a lot of force so rather than use studded bar through the centre of the bush like others have done- which restricts the diameter and therfore how strong the studded bar is going be. I'd use a hefty two armed extractor/ press and a thick steel plate at the rear of the bush mount and push the bush in that way as then you can have a hefty thread, thick diameter screw and a fine thread for more power without stripping the thread
Still get someone else to do it
