- Joined
- Apr 26, 2011
- Messages
- 2,102
- Points
- 373
..is out.
But you can't download it yet, as there isn't a link available when you select the car/generation. Those of us with the later B&M unit in the car (Mid 2011 on) should be able to get the update when it's actually available for download.
They've also created an 'assisted mode' where you download a small 'update'/piece of code that drags out the config from your B&M unit and then you upload it to them so they give you the appropriate download. Easy way to check is if you've got an 'IMAGE ID' menu item under SETTINGS>ADVANCED SETTINGS in the menu; if you have, you have a second generation B&M unit.
As soon as I see the download available, I'll update this thread...
