Technical  auto-transmission delay
MortenQubo
Copenhagen
QUBO auto-transmission delay
Hi. Does anyone discover a delay in shifting when gearbox is cold?
My Qubo 1,3 diesel 2013 have a 2 sec delay when shifting from 3rd to 4.th gear.
She behaves normal after a half hour driving.
She has the same issue no matter using manual or autoshift. No beepsounds or warnings in display.
Best regards from Denmark
Hi Charlie. Thanks for reply.
Its ‘s like pausing between 3 and 4th. No drive, no torque. If you just keep the gaspedal at same place it will get to 4 th. If you push the pedal it will jump to #2 .
Still only when cold or within the first 30 min drive. After 30 min it works perfect.
Note: if pushing the engine by stepping the gaspedal half way down and keep it there it will shift to:
#2 at 2500 rpm
#3 at 3000 rpm
# 4 at 4200 rpm; this shift will be smooth and quick but too late in my opinion since 4200 rpm seems too rapid for a diesel ...
