Technical  auto gearbox relay
howy
stokesley
Hi, Qubo has been stood a few days tried to start battery flat for some reason,so with the dud battery out removed the fuse box cover which seems impossible otherwise,so which number under the cover is the auto box pump drive relay ,i've got a fault code p1769 relay stuck intermittent, It might be a bad connection so i've moved them all,Ill try it with a new battery when I get one.
cheers.
Hi, 'I've noticed at the bottom of the page enable push notifications,I' m 81 years old and haven't got a clue what it means:unsure:
