i have a 1996 punto 60 selecta automatic,when i drive along the road the automatic warning light comes on. i have checked the oil level and thats ok, it also drives ok . any suggestions??????????:bang:
hi theremy 2001 punto has this problem but when i took it to the fiat shop:bang: they first told me that whats happen never happen all they could tell me is that it was a fault and it's number was p0705 whitch when i looked it up on the net it told me it was Transmission Range Sensor Circuit Malfunction (PRNDL Input) can any one help me with this
as t4 says throttle switch adjustment or just simply replacement may sort it as it's driving normally
common fault
i serviced one a wile ago and found someone must have forced the throttle back as it had popped the switch out of holder causing intermittent/permanent light yet driving normally
but a few other basic things you can do check the transmission oil level
if it's low it may overheat and cause problems
another common fault on these box's is the park neutral switch on not sure if it's in the box or on the gear lever
as when you brake the power is going down the reverse light circuit instead and causing it to think it's in reverse hence the error code you have
it's most likely to be a bad connection between the wiring and the lamp unit itself you need to pay most atension to the cleanliness of the black wires connector
then you will need to have the error code erased
if you operate the rear lights and indicators wile someone looks at them you will probably notice they are acting up and flashing on and off with the indicators a bit like a christmass tree
