Technical ARB bushes
thanx
i will order some of them then
will be an easy job after replacing 5 valves, guides,seals,followers shims belts,pulleys etc and refitting
peace
ordered mine today from superflex :)
fitting should be simple
i will take pics of the job if anyone is interested start to finish?
although its a relatively simple task to do
peace
fitted the arb's from superflex (y)
took pics
should i start a thread with pics ?
maybe it would be easier
peace
hello my Multi was banging and creaking like a good one so i checked ARB bushes they were worn badly .
Phoned SAF wanted £29 each sh.t I thought phoned Fiat dont do em want me to replace whole AR bar at well over £130 plus the dreaded ...
took them off put a chisel between the brackets split real easy, trimmed about 2mm of split in Bush greased and packed inbetween bottom bracket and bush with 4mm rubber matting .
Reassembled connected drop links.......
BINGO no more knocks and Bangs and better on corners ...
Took about and Hour cost sweet FA
I love the good old ways .
Marc :slayer:
Just did the same using pieces of an old cam belt, seems to be working well so far. Bodging, you can't beat it!
They look like the original rubber bushes to me :( Fit the poly's then you won't have to buy another set in a few thousand miles (y)
