phone see the adapter and pairs with pin code in blue tooth settings.
Yep phone pairs to dongle. Tested in a friends car (also Panda), and it works perfectly.phone see the adapter and pairs with pin code in blue tooth settings.
thanks, thats great progress, leave it with me. I we continue to the next step when I get back just going out for a few hoursYep phone pairs to dongle. Tested in a friends car (also Panda), and it works perfectly.
Done, still the same.Lets start with the simple
The engine computer can get itself into a kind of knot and a restart is required
disconnect the battery negative, press the brake pedal a few times, and reconnect
turn the ignition on but dont try starting the and try to establish connection again
Aldi scanner was returned as at the time I didn't know it was the car that was faulty and not the scannertry
settings -> adapter ELM --> advanced -> send 64 change to 96
have you also tried your aldi scanner now you have fixed the pins
3 LEDs yep, green yellow red. Red is power. When I've scanned my friends car, the green and yellow ones flash one after the other.Does your adaptor have three leds
Power
Obdii
Computer
Or similar
Are all three![]()
I'm not I'm afraid, I'm York.getting slightly scared to suggest anything
somethings will throw an engine check light. With no way to connect scanner to clear them.
Are you local to Cheshire, I can have a look for you
do you have a multi meter
www.fs1inc.com
Great, thanks.you are Good to do all the tests in the above link
