johnsonolly
- Joined
- Oct 19, 2021
- Messages
- 47
- Points
- 11
Never noticed anything awry with temps, gauge goes up to halfway and stays there after the first couple of miles.been thinking about this one, struggling to find a cheap and easy way to proceed
You dont always hear the fans due to road noise except at idle. Sometimes you see the coolant temperature gauge alter. Should raise to mid way in the First couple of miles and stay there, Unless the interior heaters are blowing full.
intermittent faults can be a pain. If it was my car I would run around with a flight recorder connected. Set to log the sensors and battery voltage to an SD card to be viewed later. It can get expensive changing thing on a gut feeling only to find the fault still present.
Now its known for the engine failure, hill-hold failure, ESP failure to flash up due to one faulty sensor it seem likely its not as expensive as a new set of electronics. Hopefully Good news.
"stalled almost immediately upon accelerating again and requires another 1-2 restarts before it’s happy"
again this "could" point to a sensor. They sometimes give wild reading then fine when they cool down a bit
I am moving away from earth/wiring fault
if I can't connect to the ECU its probably a traffic jam on the B CAN network most things uses the same two wires. Id probably start by disconnecting the phone receiver and radio and see if then connected.
What sort of recorder would I need to log any faults please?
For disconnecting, the phone receiver as in the bluetooth module I installed? The one I have is similar to this one, it plugs straight into the back of the radio. And for the radio, would you suggest all the connectors or specific ones.
Thanks again for your help.
