Technical Annoying noises!
wolvescinq
Hi guys!
Noise 1 : A whirring that stops when you depress the clutch pedal - despite the clutch being replaced less than 2 weeks ago. I had this noise with the old clutch, making me think I may as well have stuck with it!
Noise 2 : A constant whirring ever since a new engine mounting bolt was fitted yesterday. The engine does not seem to be sitting right now, either - it's canted up on the right hand side as you face the front of the car. Is this playing a part?
Any ideas?
. was the clutch release bearing changed with the clutch ??
Yes - the mechanic showed me the old clutch and release bearing, so I could see the wear. Thanks for the tip re. oil change - sounds like the next job on the car.
