Hi All,
I'm new to this and Fiats if I'm honest. I'm not much of a mechanic either, so all is going really well.
The problem is an S-Reg Punto 1.2s. Won't start without jumpleads, won't run immediately after starting with the jump if I take the leads off, and measuring the voltage across the battery without the leads (after the car has run for a good 10 minutes with the jump leads on) the voltage plummets - starts at 14ish and drops until it hits 5v and the car stalls. This takes about 30 seconds.
When running, no warning signs are illuminated in the car. When I switch on the ignition (after a full battery charge) all lights are illuminated as you would expect (battery, oil etc.) then go out when the car is started. The car starts fine with a jump.
There are no belt squeaking noises and I'd have thought that if it was that loose the battery light would be on in the car when it ran. Also I cannot move the belt on the pulleys.
Any thoughts or suggestions please?
Ah - the previous owner has just informed me that he tried the jump the car and managed to put the jumpleads on backwards - i.e. red to black, black to red with the other car. "There was a lot of smoke from the alternator'. Perhaps this has something to do with it?!
Thanks!
Tex
Thanks!
Tex
