Technical  alarm problems
shoxik
Enfield
just recently got a seicento that had been sitting in a garage for several years and the battery is dead, after charging the battery and putting it back in the car as soons a turn the ignition the alarm is set off and cannot be stopped :bang:, how do i go about fixing this?
thanks
scott
thanks
scott
Find and remove the alarm fuse until you can get more info on the alarm.
thanks will the fuse for the alarm be in the main fuse box or in a seperate one?
thanks
scott
You'll probably have to trace the wires back because of it being aftermarket it could be anywhere. I'd expect an in line fuse to be there or for it to share a fuse with something else
It all depends on who installed the alarm and how sensible they were thinking.
If the alarm can be switched off by simply removing a fuse, then if they were thinking straight, the fuse will be well hidden.
I would be tempted to download the wiring diagram and remove all the alarm wiring and reinstate the original, unless you can quickly get a handle on how its been wired.
the problem is i dont have the manuel for the alarm so i haave no ides where and what it is
i have found the fuses and pulled them out and the engine would turn over, i left the car to go have lunch and when i come back the alarm was going off again when i tried to turn the car on :(. i have now bought i new battery and have the same problems :mad:
