david goodwin
how do u replace the aerial cable in a fiat seicento sporting? :worship:
im trying to run a new cable through but the old 1 will not move so im wondering what could be stopping itHi
The simplest is to pull the damaged end out and stick (solder and heat shrink) on a new bit of wire and push it back.
The alternate is to butt a new cable with the old and heat shrink them together and attempt to pull the new cable through by pulling the old from the other end.
If that fails you will need to run a new cable which wont be that easy...
Noel
