General  advice
General  advice
Hi webbo, id say check all the usual things cambelt/water pump, head gasket etc. Check g box oil has been changed ive seen that cld be an issue on here. Ive seen some jtd s done over 500 k miles not joking!, if looked after so miles shldnt be prob if its been looked after. Hpe that helps. Neil.
hi all im thinking of getting a doblo, its a 1.9 jtd elx the only thing worrying me is that it has 189,000 on the clock , its a 2003 model
the engines are pretty tough,
servicing is the key, ;)
trim + suspension are the obvious things at higher mileages,
LONG MOT , and price are important.., :)
Charlie
If you want to post what/hasnt been done as regards sh etc im sure well all chip in advice. Neil.
Also check when air filter last changed as 2 of my 3 bolts are so rusted/turned ill prob hve to drill them out.
To be honest I don't like the old 1.9 jtd, much prefer the 1.3 jtd,and they are chain engine so no need to work about cam belt
I've read a fair few stories online where the timing chain has broken on the 1.3 Multijet. Some say it's down to poor oil maintenance? With ~80k on the clock (and a service history that suggests the previous owner (royal mail) changed the oil every 10-15k), I was thinking about changing mine as a preventative measure.
What do Fiat say is the service life for the timing chain assuming regular oil changes?
Many thanks
P.S. Sorry for hijack :)
Dont really understand not liking 1.9 jtd far better than 1.3 id avoid those engines like the plague, cam chain snap and a litany of other probs. Btw did u look at doblie, wss it any good?. Neil.
