Miso
Hi all,
my first post here, it's a great forum. i didn't want to create another indicator problem thread, but i just can't find my specific case..
One morning NONE of my turn signals worked, while relay CLICKING RAPIDLY.
I checked the fuse - OK, checked 5 of 6 bulbs (i still have to open stuck hard-to-get-into front left) as well as their sockets, no corrosion, no bad bulbs. but when suddenly none of them work, it shouldn't be bulbs.
No turn signals + rapid clicking also then hazard switch pressed.
All other lights work well.
Amber bulb sign showed up and disappeared several times in the past, with no effect on any car lights / indicators. now when bulb sign is off, it shows up when signaling is switched on. this is also strange - that sign should be associated only with rear light cluster excluding turn signals, iirc.
Car has no separate relay, it's on a 'motherboard' controller. Rapid clicking is a sign of life, but not a complete one, one half of it can still be faulty, if i understand it right.
So far to me it looks like grounding issue or faulty contact. If there is a short to ground, it would blow fuses. Rapid clicking occurs when the draw is less then nominal, so it should be a bad earth, right? What would be the rational succession of checking this, considering all described above ?
Thanks so much everyone who reads this puzzle.
All the best,
Mike
All the best,
Mike
