Technical Punto mk2 turn signal not working
isalopek
Croatia
Hi to.all..
So...left turn signal working, right not working (not even blinking on cluster, hazard (all 4) working normally.
Try to replace abender complete (used one same result
Put another (new one-blue) reley, solder it on bcm, same result, left working, right not, hazard all four working.
Any help appriciated.
Tnx a lot.
Model
1.2
Year
2006
Hi to.all..
Tnx a lot.
I would try switch cleaner in the hazard light switch and work it vigorously several times, other than that see if getting a signal from the indicator switch on column.
But hazard light is working normaly? Why try to clean it?
On second, i tried to see wireing diagramz bit dont understand it right..
Maybe have some directions?
Tnx a lot.
Tnx a lot.
When hazard switch goes off it reconnects to the normal indicators, it has worked for me in the past and costs nothing to try.:)
